Can't installing NVIDIA drivers in Clear Linux OS* - native and tls 4.19* (HELP)
Hello, I tried to install drivers from NVIDIA 2 times … I use the key for installation --no-cc-check however, nothing works after such an installation, but during a normal installation, which is described in your link https://docs.01.org/clearlinux/latest/tutorials/nvidia.html the drivers are not installed!
[ERROR] bad return module kernel …
Have you tried this tutorial?
Great, the scripts worked, yet it’s my crooked hands!!!) Thank you for help!
