Clear Linux on Minis Forum HM90
I have installed Clear Linux on a Minis Forum HM90.
This model contains the AMD Ryzen 9 4900H and uses a NUC like format
Since it was a barebones I installed a WD Black 770 NVMe drive and 64 Gb of GSkill RAM.
For video I am using the DP Alt Mode through the forward USB-C port.
I removed the AMD/Mediatek Wifi controller and replaced it with an Intel AX210.
So far all the interfaces have worked without issue.
This includes:
  • Front and rear USB ports
  • Both network ports (1GbE-Realtek/2.5GbE Intel I-225V)
  • Audio works just fine
The AMD IOMMU is enabled properly at boot and therefore KVM works great.
Some Linux spins (Debian/Ubuntu based) are having an issue with how the IOMMU and SVM are presented on this model, that is why I am checking Clear Linux and it seems to be doing OK.
Proxmox had some issues with the IOMMU but I was able to fix it and install it.
Passmark for Linux shows the following:
AMD Ryzen 9 4900H with Radeon Graphics (x86_64)
8 cores @ 3300 MHz | 62.2 GiB RAM
Number of Processes: 16 | Test Iterations: 1 | Test Duration: Medium
CPU Mark: 21330
Integer Math 68917 Million Operations/s
Floating Point Math 41446 Million Operations/s
Prime Numbers 43.6 Million Primes/s
Sorting 33298 Thousand Strings/s
Encryption 20410 MB/s
Compression 295439 KB/s
CPU Single Threaded 2884 Million Operations/s
Physics 1081 Frames/s
Extended Instructions (SSE) 16341 Million Matrices/s
Memory Mark: 2826
Database Operations 6211 Thousand Operations/s
Memory Read Cached 30783 MB/s
Memory Read Uncached 18391 MB/s
Memory Write 9239 MB/s
Available RAM 21307 Megabytes
Memory Latency 48 Nanoseconds
Memory Threaded 39099 MB/s
GeekBench5
1294 - Single-Core Score
8582 - Multi-Core Score
As soon as I get some rational disk tests done, I will pass along
edwaleni@clr-19e5c9d206c449c6bc59667ddabc954a~ $ sudo hdparm -tT /dev/nvme0n1p1
Password:
/dev/nvme0n1p1:
Timing cached reads: 22600 MB in 2.00 seconds = 11310.59 MB/sec
Timing buffered disk reads: 148 MB in 0.06 seconds = 2494.14 MB/sec
CrystalDiskMark 8.0.4 x64 (C) 2007-2021 hiyohiyo
Crystal Dew World: https://crystalmark.info/
  • MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
  • KB = 1000 bytes, KiB = 1024 bytes
[Read]
SEQ 1MiB (Q= 8, T= 1): 6771.193 MB/s [ 6457.5 IOPS] < 1082.86 us>
SEQ 1MiB (Q= 1, T= 1): 12230.500 MB/s [ 11663.9 IOPS] < 85.28 us>
RND 4KiB (Q= 32, T= 1): 383.510 MB/s [ 93630.4 IOPS] < 330.79 us>
RND 4KiB (Q= 1, T= 1): 3210.446 MB/s [ 783800.3 IOPS] < 0.89 us>
[Write]
SEQ 1MiB (Q= 8, T= 1): 5229.494 MB/s [ 4987.2 IOPS] < 1401.56 us>
SEQ 1MiB (Q= 1, T= 1): 5661.219 MB/s [ 5399.0 IOPS] < 184.46 us>
RND 4KiB (Q= 32, T= 1): 366.093 MB/s [ 89378.2 IOPS] < 346.52 us>
RND 4KiB (Q= 1, T= 1): 2513.803 MB/s [ 613721.4 IOPS] < 1.23 us>
Profile: Default
Test: 1 GiB (x2) [C: 16% (148/916GiB)]
Mode: [Admin]
Time: Measure 5 sec / Interval 5 sec
Date: 2022/07/02 14:55:22
