Hi, I’m considering a usb boot /test run for an older macbook air. Any recommendation on a release that will recognize the hardware (trackpad, wifi, speakers), as well as be a good choice for low ram 4GB? (One of the good things about Macos is it ram memory management!) I’m basically testing to see if I could eventually create a multiboot. A number of post have made that seem like a risky proposition so far. Ventoy seemed promising however it would require a dual boot with Windows, so I may have to set-that up first and then look at trying out Clear and other Linux distros. Spec below; open to suggestions. Thanks.
| Model Identifier:|MacBookAir5,2|
| Processor Name:|Dual-Core Intel Core i5|
| Processor Speed:|1.8 GHz|
| Number of Processors:|1|
| Total Number of Cores:|2|
| L2 Cache (per Core):|256 KB|
| L3 Cache:|3 MB|
| Hyper-Threading Technology:|Enabled|
| Memory:|4 GB|
