Connecting VLC to MakeMKV
Does any one know how to connect CL’s native VLC to the Flatpak Make MKV? Things are pretty easy with the Flatpak VLC, though org.videolan.VLC.Plugin.makemkv doesn’t seem to work with CL’s VLC.
So, are you using this Bundle?
swupd bundle-add vlc
Yes, I am using the VLC bundle … only because it is required by some other bundle (desktop-kde), which, in turn, I am not sure what is required for … At any rate, I would have preferred to use the Flatpak VLC, which is already “tuned” for Blu-Ray and DVD playback thanks to the above mentioned VLC plugin, though I am not a fan of having two copies of the same application installed on my system.
