2020/06/22 03:12:21 [ERR] An error occurred executing command: "swupd os-install --statedir-cache=/var/lib/clr-installer/offline-content --path=/tmp/install-450069537 --statedir=/tmp/install-450069537/var/lib/swupd -V 33410 --force --no-boot-update --json-output -B os-core-update,openssh-server,c-basic,desktop-autostart,git,vim,NetworkManager,telemetrics,sysadmin-basic,tzdata,kernel-native". Error: signal: bus error (core dumped)
2020/06/22 03:12:21 [INF] Umounting rootDir: /tmp/install-450069537
2020/06/22 03:12:21 [DBG] Unmounted ok: /tmp/install-450069537/sys
2020/06/22 03:12:21 [DBG] Unmounted ok: /tmp/install-450069537/proc
2020/06/22 03:12:21 [DBG] Unmounted ok: /tmp/install-450069537/dev
2020/06/22 03:12:21 [DBG] Unmounted ok: /tmp/install-450069537/boot
2020/06/22 03:12:23 [DBG] Unmounted ok: /tmp/install-450069537
2020/06/22 03:12:23 [INF] Removing rootDir: /tmp/install-450069537
2020/06/22 03:12:23 [INF] Running post-image hooks
2020/06/22 03:12:23 [INF] Installation Steps Complete
2020/06/22 03:12:24 [DBG] timeout --kill-after=30s 30s curl --no-sessionid -o /tmp/clr-installer-yaml-141400315 -s -f https://cdn.download.clearlinux.org/releases/33410/clear/config/image/.data/post-gui-install-msg.yaml
2020/06/22 03:12:24 [DBG] sync user is PKEXEC_UID=#1000
2020/06/22 03:12:24 [DBG] Gnome Proxy Mode: none
2020/06/22 03:12:24 [DBG] [Previous line repeated 4 times]
2020/06/22 03:12:24 [DBG] cmd.Env: []
2020/06/22 03:12:24 [DBG] Post-Installation has no message content
We have seen swupd occasionally fail, but any helpful information as to why would be before that error message.
@Ziaur_Rahman If this is reproducible, could you share the entire clr-installer.log as glist or as an attachment to a GitHub Issue.
