Hi everyone, I have a problem on a working laptop.
swupd is not able to run, in any way, it crash with core dump whatever I try to do.
I have booted on the ISO clear linux desktop but the result is the same, find hereafter a summary.
clrlinux@clr-live~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 2.7G 1 loop
sda 8:0 0 119.2G 0 disk
├─sda1 8:1 0 149M 0 part
└─sda2 8:2 0 119.1G 0 part
sdb 8:16 1 7.2G 0 disk
├─sdb1 8:17 1 7.2G 0 part
└─sdb2 8:18 1 32M 0 part
clrlinux@clr-live~ $ sudo su -
root@clr-live~ # mount /dev/sda2 /mnt
root@clr-live~ # df
Filesystem 1K-blocks Used Available Use% Mounted on
none 524288 18268 506020 4% /
devtmpfs 1905708 0 1905708 0% /dev
tmpfs 1947660 0 1947660 0% /dev/shm
tmpfs 779068 1152 777916 1% /run
tmpfs 4096 0 4096 0% /sys/fs/cgroup
tmpfs 1947664 0 1947664 0% /tmp
clr_debug_fuse 524288 18268 506020 4% /usr/src/debug
clr_debug_fuse 524288 18268 506020 4% /usr/lib/debug
tmpfs 389532 48 389484 1% /run/user/1000
/dev/sda2 122396280 31736076 84399776 28% /mnt
root@clr-live~ # swupd repair --picky --path=/mnt --statedir=/mnt/var/lib/swupd
Diagnosing version 34300
Downloading missing manifests...
Checking for corrupt files
Bus error (core dumped)
root@clr-live~ #
dont know what to do from now to save my installation, please give me a tips or direction if you know one.
thank for your feedbacks.
regards
