Hi I’m try to open a new tty terminal using the ctl + alt + F1 keys but nothing is happening. Is there a program I have to down load to get this to work?
Currently just CLI no Desktop-gui
Also yes all other keyboard functions are working. Just seems like the OS isn’t responding to this particular command. I have a ManjaroLinux image that is working with this command
It should work starting with CTRL + ALT + F3.
Do you have Fn
key on the keyboard? Maybe try CTL + ALT + Fn +F3
Thanks that solves my issue.
