On my home PC, when I am not running web server and just focus on compiling/execution of standalone executables, I would like to disable various latest mitigations (Spectre, Meltdown etc. ) I found on other distros it can be disabled by adding in the file /etc/sysconfig/grub the line: noibrs noibpb nopti nospectre_v2 nospectre_v1 l1tf=off nospec_store_bypass_disable no_stf_barrier mds=off mitigations=off and re-generating grub’s configuration file with grub2-mkconfig
But Clear Linux doesn’t have /etc/sysconfig directory. How can I disable those mitigations?
Yes, I have read that. The question is - can I do it in some easy way through the terminal command (as Tourette has pointed), or still create the file, update clr-boot-manager, and than reboot?
So, basically it is the same old way, just simpler parameter syntax for mitigations handling. Still I need to reboot every time after updates in order to make it effective, correct?
The kernel parameters are written in the config files, and I think after the kernel update, the clr-boot-manager won’t discard/ignore these configurations.
I used the shell script you wrote, but it didn’t seem to have any effect on numerous performance intensive benchmarks. I suspect mitigations were not successfully turned off, even though I’d created /etc/kernel/cmdline.d/SOMEFILE.conf that specified they were. Do you have any ideas? Thank you so much!
