Displaylink / EVDI in Clear Linux
I’m trying to get my Displaylink device running on Clear Linux. The Ubuntu .deb file runs fine on Ubuntu/PopOS but I’m a little lost as to how to get it running on Clear Linux, and I rely on that device to operate two of my monitors. I’ve searched quite a bit but am still a little lost as to where to look
It looks like DisplayLink has been tailord for Ubuntu/Debian style systems and not all of it is open source. I imagine it will be challenge getting it to work well on any other Linux distribution.
If you’re up for the challenge, these are some links to start looking at:
Hello, I don’t know if you already installed displaylink driver.
I was able to install it on my laptop, good news:
  • You don’t have to change anything from driver’s source code.
  • You have to install kernel source and kernel dkms for your kernel version (native or lts)
lsb_release is not available in clearlinux, honestly, I don’t understand why, but you can use download this script Simple alternative to /usr/bin/lsb_release · GitHub and save it as /usr/bin/lsb_release, of course as sudo with exec permissions.
Then you have to create 2 new folders (as sudo)
sudo mkdir /etc/udev/rules.d
sudo mkdir /lib/systemd/system-sleep
Now, you just simple download displaylink’s driver from official page.
chmod +x displaylink-driver-5.2.14.run
displaylink-driver-5.2.14.run --noexec --keep
cd displaylink-driver-5.2.14
./displaylink-installer.sh install
…and reboot
Now, the bad news:
At least for me, the screens connected to the docking station have some kind of lag…
I mean, if I press keys, I don’t see the last key pressed, I see the previous one… If I open a new window or a menu, I don’t see the menu until I move the mouse… so it seems some events are missing, but this is not a driver or kernel issue, It’s gnome’s.
Before trying clear linux, I was using openSUSE tumbleweed with gnome 3.32, and everthing worked good, but after I upgraded to gnome 3.34 I had the same issue… I thought my opensuse installation got broken, so I started again with a new openSUSE installation, but the problem was there… and I couldn’t go back to 3.32
So I thought, the issue was in the kernel, so I installed ClearLinux with lts kernel, but I found this same problem, so the issue is in the gnome 3.34, I would like to build gnome 3.32 by myself but I don’t know how.
anyway, I hope you don’t have this issue.
@WBryant Have you been able to install Displaylink driver yet?
I have it woking fine now using X.org instead of wayland.
You have to follow “Configuring X Server” section at DisplayLink - ArchWiki
And also the " Workaround 2: Temporarily disable PageFlip for modesetting" section to make it work.
Hi rAngeles,
I’m trying to install the displaylink driver too. I’m getting this error when running the install command:
** No rule to make target ‘scripts/basic/fixdep.c’, needed by ‘scripts/basic/fixdep’. Stop.
thank you
Thanks, I’ll try that next time I install it, Displaylink was too critical to everyday work so I gave up.
Hi @syncord, this issue is related to linux headers installation…
I’m using LTS kernel, make sure you are installing de kernerl headers for your kernel.
regards
