Currently I’m in Debian 10 and I almost surfed most known distros and also tweaked my /etc/pulse/daemon.conf for several times and several modes and tried every latest kernel but nothing seemed worked.
Does clear linux has any edge over audio performance since my laptop audio card is intel’s one.
My pulseaudio config file
This file is part of PulseAudio.
PulseAudio is free software; you can redistribute it and/or modify
it under the terms of the GNU Lesser General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
PulseAudio is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
You should have received a copy of the GNU Lesser General Public License
along with PulseAudio; if not, see http://www.gnu.org/licenses/.
Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
more information. Default values are commented out. Use either ; or # for
commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
cpu-limit = no
high-priority = yes
nice-level = -15
;realtime-scheduling = yes
;realtime-priority = 9
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
resample-method = soxr-vhq
avoid-resampling = false
enable-remixing = yes
remixing-use-all-sink-channels = yes
enable-lfe-remixing = no
; lfe-crossover-freq = 0
; flat-volumes = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
rlimit-rtprio = 9
; rlimit-rttime = 200000
default-sample-format = float32le
default-sample-rate = 96000
alternate-sample-rate = 48000
default-sample-channels = 2
default-channel-map = front-left,front-right
default-fragments = 4
default-fragment-size-msec = 125
enable-deferred-volume = yes
deferred-volume-safety-margin-usec = 8000
deferred-volume-extra-delay-usec = 0
