Does Clear Linux supports dual monitor setup?
I am using dual monitor setup with windows 10. I just wanna make sure that if I install Clear Linux , is it gonna support my extended display / dual monitor setup.
I use it with multiple monitors. This will depend more on your graphics device but in general isn’t an issue.
I use three, sometimes four, but the three are bolted to a rolling crash cart, and I don’t typically carry the fourth along. I often connect to or just cast out to large television screens as well. I’ve found display management to be slightly easier that windows 10, only because with windows 10 you have to keep clicking “Identify displays” when setting up multiple monitors, whereas in (GNOME) they are allways identified while you are adjusting display settings.
