Hello,
I noticed a bug using two Wifi connections. Only one WLAN interface can connect to the same hotspot, while the second one does not connect when clicking on the same SSID.
I can connect to two different hotspots without problems, just not the same ones. When clicking on the same SSID, nothing happens. The Wifi password is shown correctly when unhidden, just it does not make an attempt to connect.
Config
- Intel ComputeStick STK1AW32SC
- USB Wifi dongle “Realtek Semiconductor Corp. RTL8811AU 802.11a/b/g/n/ac WLAN Adapter”, driver is from GitHub - aircrack-ng/rtl8812au: RTL8812AU/21AU and RTL8814AU driver with monitor mode and frame injection
