Hello I decided to move to Clear Linux. How can I setup ExpressVPN?
With Ubuntu was quite straight forward, has someone already installed it in Clear Linux?
Thanks and Regards
Thanks and Regards
I reply to myself, I solved it using their predefined configurations.
Yeah, many of these VPN providers have closed-source applications built for other distros like Ubuntu and Fedora that don’t have a straightforward way of installing on Clear Linux.
All of them provide OpenVPN configuration files which can be used on the command line or integrated with NetworkManager though.
Yes, you are right, almost every vpn has closed-source applications built for other distros like Ubuntu and Fedora. And yes ExpressVPN offers OpenVPN protocol and you can get OpenVPN configuration files via online chat of ExpressVPN.
How can you achieve that?
ExpressVPN support simple answer me: not supported…
