Hi,
Here is a fast and easy way to install openvpn on Clear Linux OS
( I’m using SurfShark but it is the same for other providers )
Everything in root mode :
Installing
swupd bundle-add unzip;
swupd bundle-add network-basic;
mkdir /etc/openvpn;
cd /etc/openvpn;
wget https://my.surfshark.com/vpn/api/v1/server/configurations;
unzip configurations;
Running
cd /etc/openvpn;
ls | less; # List all disponible VPN
openvpn <VPN_selected_on_the_list>; # Choose a VPN on the list
Example :
I choose on the list : Jakarta on udp
openvpn id-jak.prod.surfshark.com_udp.ovpn
Login :
With given credential ( given by SurfShark in my case )
Checking with :
https://whatismyipaddress.com/
Everything OK, I’m now on Jakarta, Jakarta Raya, Indonesia
Stopping
Ctrl + C
Best regards,
ClearLinux.User.809
