I don’t know if it’s an easy thing to implement or not but just thought I’d ask. Usually with things Clear Linux doesn’t have by default I will either build myself or run a docker session on the host with xhost forwarding. Works great for most apps like OBS. However, building KDE connect I couldn’t even get past the download screen, and docker xhost doesn’t fly either. A full blown distrobox session running fedora rawhide works. As a side note, running fedora in distrobox via Clear Linux is actually faster than running fedora natively. Hehehe, gotta love Clear Linux
I’m on Gnome, not KDE, so I haven’t tried it, but we do list kdeconnect-kde in swupd, so you should be able
sudo swupd bundle-add kdeconnect-kde
Chris
Thanks! Works perfectly.
