On all CL installations I cannot format anything with ext4 as the extension is missing:
mkfs mkfs.btrfs mkfs.ntfs
You can try searching for the “missing” utilities:
user@host~ $ sudo swupd search mkfs.ext4
Bundle with the best search result:
storage-utils - Run disk and filesystem management functions. (38MB)
This bundle can be installed with:
swupd bundle-add storage-utils
To confirm this:
user@host~ $ sudo swupd bundle-info --files storage-utils | egrep ext4
- /usr/share/man/man8/mkfs.ext4.8
- /usr/share/man/man8/fsck.ext4.8
- /usr/share/man/man5/ext4.5
- /usr/lib64/autofs/mount_ext4.so
- /usr/bin/mkfs.ext4
