I can’t mount my ntfs drives with NTFS3, only with ntfs-3g fuse. Is there a bundle that I have to download ?
TY
TY
Try :
sudo swupd bundle-add ntfs-utilities
Try with:
sudo swupd bundle-add storage-utils
It does not exist.
Loading required manifests…
Warning: Bundle “ntfs-utilities” is invalid, skipping it…
Failed to install 1 of 1 bundles
It’s already installed. Putting in fstab or trying to mount to NTFS3 (and not ntfs-3g) doesn’t work at all, as if it doesn’t exist.
How do you try to mount it??
Like this?
/dev/NTFS-part /mnt/windows ntfs-3g defaults 0 0
Well yes but I’m talking about NTFS3 and not ntfs-3g which are different things. ntfs-3g works but not NTFS3
It does not include in the initrd. It does not compile by default.
You can check it: linux/config at 551f0d9d6a2679db0bdb6cd0f9692bfcc5cacd02 · clearlinux-pkgs/linux · GitHub at line 9451
# CONFIG_NTFS3_FS is not set
# CONFIG_NTFS_FS is not set
If you want to include it, you should modify and compile it.
How do I do this ? I’m new on linux I just tested Arch before and I used NTFS3 without issues. Do you have any tutorial or ressources so that I can do this ?
You could follow this guide: Kernel development — Documentation for Clear Linux* project
The ClearMod project enables NTFS3.
Extract taken from the spec file.
# NTFS3 is a kernel NTFS implementation, which offers much faster
# performance than the NTFS-3G FUSE based implementation.
# Note: ntfs3 requires the file system type to mount.
# e.g. mount -t ntfs3 /dev/sdxY /mnt
# https://www.paragon-software.com/home/ntfs3-driver-faq/
# https://wiki.archlinux.org/title/NTFS
scripts/config -m NTFS3_FS
scripts/config -d NTFS3_64BIT_CLUSTER
scripts/config -e NTFS3_LZX_XPRESS
scripts/config -e NTFS3_FS_POSIX_ACL
Thanks but what is ClearMod/XanMod ? A modified kernel ? Will it get automatically updated when doing swupd update ? And will it be maintained (I guess your the maintainer of this projet). Also I think I’ve seen you on the CachyOS discord posting benchmarks and everything, do you think there is a way to enable sch_ext on Clear ? Sorry if I asked too many questions lol.
No. Kindly ask the Clear team to enable NTFS3_FS
, NTFS3_LZX_XPRESS
, and NTFS3_FS_POSIX_ACL
in their native kernel.
No. The ClearMod repo is in archived state.
Not tried.
