There are tons of docker containers being published with a premade folding client, unfortunately it’s kind of a wild west right now: Docker
Even on a supported distro like Ubuntu the client side download for folding is problematic, I opted to join rosetta@home instead, which is also solving for covid-19: swupd bundle-add boinc-client and then run boinc and register with the project.
dear @ahkok thankyou - I was not aware that this has been discussed on github already.
@castrojo docker is a good alternative - i was thinking about it aswell. In the past I did some projects with gpu passthrough but I was hoping that there is a more native approach. I will use boinc instead as you mentioned. F@H has already issues to distribute enough packages. My Desktop has no WU and is ideling (gpu)
slightly ot but it is related to your suggestion. Does boinc correctly regocnize your GPU ? (I have cuda installed and it shows up in nvidia-smi aswell but …none of it can be seen by boinc)
