In that article, its mentioned that CL utilizes the GPT Type code 8304 to find the root filesystem and mount it. I have my home partition set with type code 8302 (the Linux /home partition type code) but CL/systemd is not automounting it.
This has worked in ArchLinux before and I don’t recall needing to do anything other than apply the type codes. Is this something CL can accomplish? Am I missing a step and maybe this should already happen?
The rootfs is passed to the kernel by PARTUUID. I’m not sure where you get the information on the MNT_HOME from, though, using labels shouldn’t happen. systemd can likely mount /home filesystems automatically, and we should just rely on that.
I think it was confused with partition labels such as CLR_MNT_/home which the clr-installer can use to identify target partitions for advanced partitions during installation.
The systemd auto mounting should work if the partition GUID is set. I don’t think partition type ID is enough. systemd-gpt-auto-generator
I needed to add 4 partitions to my CL system.
/share (a user shared system between distros)
/backup for alternate day backups
/scratch1 for development
/scratch2 an alternative for /tmp, eg larger downloads
I created the mount points via mkdir and filled in the /etc/fstab
using info from sudo blkid or sudo lsblk -o …
So, I have a mix of CL owned partitions and my own. My system works just fine (2 months with no problems).
I am an idiot though and named the partition CLR_HOME. haha. Whoops. Anyway, it seems I could go back and either apply this route or continue to try to figure out why the type partition code is not making the partition get auto-mounted to /home.
I’m disinclined to pursue the former because I don’t want to have partition names assigned that represent just a single distro when I share my home partition across multiple. I mean I like CL, but I can be a little bit of a distro-holic
As for the latter, I’m going to see if I can follow the boot log and dmesg a little more to debug what is going on. I believe this to be more of a configuration issue with me and systemd rather than a CL issue.
