I’m not sure why but today, the system started bringing up the command prompt login screen after booting.
Tried to get GDM up manually with:
sudo gdm
and
startx
Both command failed.
Tried to upgrade the system and followed the “Fix a broken installation” guide, but nothing changes.
First check if X is not already running.
startx -- :1
Maybe the GDM process was already running and blocking DISPLAY :0
If that doesn’t work, try removing these 2 files and try again :
/home/username/.XAuthority*
/opt/.X0-lock
Sometimes these files are in a different location, to find the exact one, type :
updatedb
locate *part of filename*
This filesearch uses mlocate, which is in the findutils bundle
sudo swupd bundle-add findutils
If startx – :1 doesn’t work, try startx – :7
Sometimes X won’t start because of a lack of free space on your disk.
df -Th
Also try
sudo systemctl status lightdm
sudo systemctl service lightdm start
Tried
“startx – :1” up to “startx – :8” don’t worked.
Don’t had either these files.
Just result in a black screen with “_” blinking in the top left of the display.
The system have about 60 Gigs free space remaining.
At the end of the warning, when I enter 'startx" I notice this recommendation: “Please also check the log file at “/var/log/Xorg.0.log” for additional information.”
Here is:
[ 66.791]
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
[ 66.791] Build Operating System: Linux 5.2.3-809.native x86_64
[ 66.791] Current Operating System: Linux clr 5.2.17-836.native #1 SMP Sat Sep 21 00:13:02 PDT 2019 x86_64
[ 66.791] Kernel command line: initrd=\EFI\org.clearlinux\freestanding-00-intel-ucode.cpio initrd=\EFI\org.clearlinux\freestanding-i915-firmware.cpio.xz root=PARTUUID=bdc6cf71-81d6-4c3b-b5b9-5ea5639d3495 quiet console=tty0 console=ttyS0,115200n8 cryptomgr.notests init=/usr/bin/initra-desktop initcall_debug intel_iommu=igfx_off kvm-intel.nested=1 no_timer_check noreplace-smp page_alloc.shuffle=1 rcu_nocbs=0-64 rcupdate.rcu_expedited=1 rootfstype=ext4,btrfs,xfs tsc=reliable rw module.sig_unenforce
[ 66.791] Build Date: 31 May 2019 06:47:02PM
[ 66.791]
[ 66.791] Current version of pixman: 0.38.4
[ 66.791] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 66.791] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 66.796] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep 27 16:46:47 2019
[ 66.797] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 66.798] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 66.799] (==) No Layout section. Using the first Screen section.
[ 66.799] (==) No screen section available. Using defaults.
[ 66.799] (**) |-->Screen "Default Screen Section" (0)
[ 66.799] (**) | |-->Monitor "<default monitor>"
[ 66.799] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 66.799] (==) Automatically adding devices
[ 66.799] (==) Automatically enabling devices
[ 66.799] (==) Automatically adding GPU devices
[ 66.799] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 66.799] (==) FontPath set to:
/usr/share/fonts/X11/misc/,
/usr/share/fonts/X11/TTF/,
/usr/share/fonts/X11/OTF/,
/usr/share/fonts/X11/Type1/,
/usr/share/fonts/X11/100dpi/,
/usr/share/fonts/X11/75dpi/
[ 66.799] (**) ModulePath set to "/usr/lib64/xorg/modules,/opt/nvidia/lib64/xorg/modules"
[ 66.799] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 66.799] (II) Loader magic: 0x558de0948020
[ 66.799] (II) Module ABI versions:
[ 66.799] X.Org ANSI C Emulation: 0.4
[ 66.799] X.Org Video Driver: 24.0
[ 66.799] X.Org XInput driver : 24.1
[ 66.799] X.Org Server Extension : 10.0
[ 66.799] (++) using VT number 1
[ 66.801] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 66.804] (--) PCI:*(1@0:0:0) 10de:0fd5:106b:010a rev 161, Mem @ 0xb0000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00002000/128, BIOS @ 0x????????/524288
[ 66.804] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 66.804] (II) LoadModule: "glx"
[ 66.804] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 66.804] (II) Module glx: vendor="X.Org Foundation"
[ 66.804] compiled for 1.20.5, module version = 1.0.0
[ 66.804] ABI class: X.Org Server Extension, version 10.0
[ 66.804] (==) Matched nouveau as autoconfigured driver 0
[ 66.804] (==) Matched nv as autoconfigured driver 1
[ 66.804] (==) Matched modesetting as autoconfigured driver 2
[ 66.804] (==) Matched fbdev as autoconfigured driver 3
[ 66.804] (==) Matched vesa as autoconfigured driver 4
[ 66.804] (==) Assigned the driver to the xf86ConfigLayout
[ 66.804] (II) LoadModule: "nouveau"
[ 66.804] (II) Loading /usr/lib64/xorg/modules/drivers/nouveau_drv.so
[ 66.804] (II) Module nouveau: vendor="X.Org Foundation"
[ 66.804] compiled for 1.20.5, module version = 1.0.16
[ 66.804] Module class: X.Org Video Driver
[ 66.804] ABI class: X.Org Video Driver, version 24.0
[ 66.804] (II) LoadModule: "nv"
[ 66.805] (WW) Warning, couldn't open module nv
[ 66.805] (EE) Failed to load module "nv" (module does not exist, 0)
[ 66.805] (II) LoadModule: "modesetting"
[ 66.805] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 66.805] (II) Module modesetting: vendor="X.Org Foundation"
[ 66.805] compiled for 1.20.5, module version = 1.20.5
[ 66.805] Module class: X.Org Video Driver
[ 66.805] ABI class: X.Org Video Driver, version 24.0
[ 66.805] (II) LoadModule: "fbdev"
[ 66.805] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 66.805] (II) Module fbdev: vendor="X.Org Foundation"
[ 66.805] compiled for 1.20.5, module version = 0.5.0
[ 66.805] (II) LoadModule: "vesa"
[ 66.805] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 66.805] (II) Module vesa: vendor="X.Org Foundation"
[ 66.805] compiled for 1.20.5, module version = 2.4.0
[ 66.805] (II) NOUVEAU driver
[ 66.805] (II) NOUVEAU driver for NVIDIA chipset families :
[ 66.805] RIVA TNT (NV04)
[ 66.805] RIVA TNT2 (NV05)
[ 66.805] GeForce 256 (NV10)
[ 66.805] GeForce 2 (NV11, NV15)
[ 66.805] GeForce 4MX (NV17, NV18)
[ 66.805] GeForce 3 (NV20)
[ 66.805] GeForce 4Ti (NV25, NV28)
[ 66.805] GeForce FX (NV3x)
[ 66.805] GeForce 6 (NV4x)
[ 66.805] GeForce 7 (G7x)
[ 66.805] GeForce 8 (G8x)
[ 66.805] GeForce 9 (G9x)
[ 66.805] GeForce GTX 2xx/3xx (GT2xx)
[ 66.805] GeForce GTX 4xx/5xx (GFxxx)
[ 66.805] GeForce GTX 6xx/7xx (GKxxx)
[ 66.805] GeForce GTX 9xx (GMxxx)
[ 66.805] GeForce GTX 10xx (GPxxx)
[ 66.805] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 66.805] (II) FBDEV: driver for framebuffer: fbdev
[ 66.805] (II) VESA: driver for VESA chipsets: vesa
[ 66.929] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 66.929] (EE) open /dev/dri/card0: No such file or directory
[ 66.929] (WW) Falling back to old probe method for modesetting
[ 66.929] (II) Loading sub module "fbdevhw"
[ 66.929] (II) LoadModule: "fbdevhw"
[ 66.929] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 66.929] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 66.929] compiled for 1.20.5, module version = 0.0.2
[ 66.929] ABI class: X.Org Video Driver, version 24.0
[ 66.929] (EE) Unable to find a valid framebuffer device
[ 66.929] (WW) Falling back to old probe method for fbdev
[ 66.929] (II) FBDEV(2): using default device
[ 66.929] (EE) Screen 0 deleted because of no matching config section.
[ 66.929] (II) UnloadModule: "modesetting"
[ 66.929] (II) UnloadModule: "fbdev"
[ 66.929] (II) UnloadSubModule: "fbdevhw"
[ 66.929] (EE)
Fatal server error:
[ 66.929] (EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
[ 66.929] (EE)
[ 66.929] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 66.929] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 66.929] (EE)
[ 66.934] (EE) Server terminated with error (1). Closing log file.
Read the file but can’t figured out what is the problem exactly. Maybe theses lines?
Removed the Nvidia proprietary driver and the GDM worked again in the next boot.
How did you remove the nvidia proprietary drivers?
See the documentation here: https://docs.01.org/clearlinux/latest/tutorials/nvidia.html#uninstallation
If you used the scripts @doct0rHu created to install, he also has an uninstall script.
Before you do that though, you might want to see if this workaround fixes whatever problem you’re having: GNOME fails to start after installing NVIDIA proprietary driver · Issue #1274 · clearlinux/distribution · GitHub
