Hi All,
Gimp has been acting up (crashing) since “last week” not sure on the exact CLx version, I first noticed this when trying to crop/cut images amongst other activities. This is the error message (both Wayland and Xorg, even with the Flatpak app):
Warning: Unknown input_id: -1 for input: surfacemap_x
GIMP-Message: Some fonts failed to load:
-/usr/share/gimp/2.0/fonts/
The program ‘gimp’ received an X Window System error.
This probably reflects a bug in the program.
The error was ‘BadWindow (invalid Window parameter)’.
(Details: serial 56812 error_code 3 request_code 18 minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
(script-fu:2165): LibGimpBase-WARNING **: 00:41:26.516: script-fu: gimp_wire_read(): error
This is not something I am knowledgeable on, anybody know what is going on?
UPDATE:
Updated to Clear Linux 33140 and now it won’t launch!
