Indy
March 7, 2023, 9:34am
1
I get these errors before the login screen and fixed it cosmetically by adding loglevel=3 to the kernel parameters. These errors appear to be not unique to CL.
I am worried to do the solution mentioned here to fix the decompress fail.
https://forums.debian.net/viewtopic.php?t=143741
The other error appears to be a bug in the NVIDIA driver.
I would be grateful for @pixelgeek 's or any member of the OSdevelopment team’s view on these errors if they have time.
I raised this issue with a couple of the developers. I’ll let them comment.
Indy
March 7, 2023, 10:50pm
5
Many thanks @mfdemicco . I will delete those files and see if it goes away.
Indy
March 8, 2023, 5:30pm
6
I can confirm that your solution got rid of the pstore erors. Thank you @mfdemicco .
Feedback from the engineers - these are not really messages that we have any control over
pstore errors: Delete the log files in /sys/fs/pstore? Seems like a reasonable action.
ACPI errors: check for a BIOS update
NVIDIA errors: may be the continuation of ACPI errors
Rgds,
Chris
Indy
March 9, 2023, 6:16am
8
Thanks a lot @pixelgeek .
