I just installed clear linux and I’m having a very slow boot, before installing it I checked for system compatibility and everything was OK.
Then after installing (install took so long though) I had this problem when booting:
Booting continues after that but it takes like 1 min which is so long i think.
Thanks for your help
Try this:
On boot, press and hold space, when you see the boot menu, move cursor to one kernel, press e, append these to the end:
acpi=off
Thought that worked for a moment but then i got another error and booting was as slow:
And my mouse cursor isn’t moving anymore
ahkok
April 20, 2020, 4:53am
4
ACPI errors are unlikely the cause here, I wouldn’t disable acpi=off
like that until you have tried other things.
Start with updating your BIOS first.
yes, i put “acpi=off” in the end kernel argument, gave me more error and crash. I removed it and live with error acpi in boot
