Few days ago i tried to install clearlinux but i ended up with slow loading on boot screen loading every single bit by 30 sec till it stop and waiting for an hour.
I tried older versions i tried even server version with hope maybe terminal at least will work but ended up with same issue.
Apparently this issue is with AMD CPU as my old machine running intel i didn’t had any issues.
But i found a solution maybe its not greatest but so far it works
So everything starts on boot before launch clearlinux on boot menu press on keyboard “E”
on boot options delete
console=ttyS0,115200n8
not sure if everybody have same but everything what is in console must to be deleted including word console itself
After installing os you gonna be stuck with same problem system will slowly boot till it stops.
Restart computer and before it boots in press ESC button till u be greeted with bootloader
Repeating same process and remove console
After that it should boot your system.
Then go to
/usr/lib/kernel/
find a file calls
cmdline-{version of your kernel} and open it ( i used nano )
