Hello to everyone. I’ve installed ClearLinux on my PC without much problems and everything seems to work fine. Now I’m trying to boot ClearLinux as guest OS on FreeBSD as host using the bhyve hypervisor. Unfortunately for some reason,it gets stuck on the screen,even if it gives a precise error. In the meantime I want to give you a general overview of the hardware specs of my PC :
# pciconf -lv
hostb0@pci0:0:0:0: class=0x060000 rev=0x0d hdr=0x00 vendor=0x8086 device=0x3e30 subvendor=0x1458 subdevice=0x5000
vendor = 'Intel Corporation'
device = '8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S]'
class = bridge
subclass = HOST-PCI
pcib1@pci0:0:1:0: class=0x060400 rev=0x0d hdr=0x01 vendor=0x8086 device=0x1901 subvendor=0x1458 subdevice=0x5000
device = '6th-10th Gen Core Processor PCIe Controller (x16)'
class = bridge
subclass = PCI-PCI
pcib2@pci0:0:1:1: class=0x060400 rev=0x0d hdr=0x01 vendor=0x8086 device=0x1905 subvendor=0x1458 subdevice=0x5000
device = 'Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8)'
class = bridge
subclass = PCI-PCI
vgapci0@pci0:0:2:0: class=0x030000 rev=0x02 hdr=0x00 vendor=0x8086 device=0x3e98 subvendor=0x1458 subdevice=0xd000
device = 'CoffeeLake-S GT2 [UHD Graphics 630]'
class = display
subclass = VGA
pchtherm0@pci0:0:18:0: class=0x118000 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa379 subvendor=0x1458 subdevice=0x8888
device = 'Cannon Lake PCH Thermal Controller'
class = dasp
xhci0@pci0:0:20:0: class=0x0c0330 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa36d subvendor=0x1458 subdevice=0x5007
device = 'Cannon Lake PCH USB 3.1 xHCI Host Controller'
class = serial bus
subclass = USB
none0@pci0:0:20:2: class=0x050000 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa36f subvendor=0x8086 subdevice=0x7270
device = 'Cannon Lake PCH Shared SRAM'
class = memory
subclass = RAM
none1@pci0:0:22:0: class=0x078000 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa360 subvendor=0x1458 subdevice=0x1c3a
device = 'Cannon Lake PCH HECI Controller'
class = simple comms
ahci0@pci0:0:23:0: class=0x010601 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa352 subvendor=0x1458 subdevice=0xb005
device = 'Cannon Lake PCH SATA AHCI Controller'
class = mass storage
subclass = SATA
pcib3@pci0:0:27:0: class=0x060400 rev=0xf0 hdr=0x01 vendor=0x8086 device=0xa340 subvendor=0x1458 subdevice=0x5001
device = 'Cannon Lake PCH PCI Express Root Port'
class = bridge
subclass = PCI-PCI
pcib4@pci0:0:28:0: class=0x060400 rev=0xf0 hdr=0x01 vendor=0x8086 device=0xa338 subvendor=0x1458 subdevice=0x5001
class = bridge
subclass = PCI-PCI
pcib5@pci0:0:28:6: class=0x060400 rev=0xf0 hdr=0x01 vendor=0x8086 device=0xa33e subvendor=0x1458 subdevice=0x5001
class = bridge
subclass = PCI-PCI
pcib6@pci0:0:29:0: class=0x060400 rev=0xf0 hdr=0x01 vendor=0x8086 device=0xa330 subvendor=0x1458 subdevice=0x5001
class = bridge
subclass = PCI-PCI
isab0@pci0:0:31:0: class=0x060100 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa305 subvendor=0x1458 subdevice=0x5001
device = 'Z390 Chipset LPC/eSPI Controller'
class = bridge
subclass = PCI-ISA
hdac0@pci0:0:31:3: class=0x040300 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa348 subvendor=0x1458 subdevice=0xa0c3
device = 'Cannon Lake PCH cAVS'
class = multimedia
subclass = HDA
ichsmb0@pci0:0:31:4: class=0x0c0500 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa323 subvendor=0x1458 subdevice=0x5001
device = 'Cannon Lake PCH SMBus Controller'
class = serial bus
subclass = SMBus
none2@pci0:0:31:5: class=0x0c8000 rev=0x10 hdr=0x00 vendor=0x8086 device=0xa324 subvendor=0x8086 subdevice=0x7270
device = 'Cannon Lake PCH SPI Controller'
class = serial bus
em0@pci0:0:31:6: class=0x020000 rev=0x10 hdr=0x00 vendor=0x8086 device=0x15bc subvendor=0x1458 subdevice=0xe000
device = 'Ethernet Connection (7) I219-V'
class = network
subclass = ethernet
ppt0@pci0:1:0:0: class=0x0c0330 rev=0x03 hdr=0x00 vendor=0x1912 device=0x0014 subvendor=0x1912 subdevice=0x0015
vendor = 'Renesas Technology Corp.'
device = 'uPD720201 USB 3.0 Host Controller'
class = serial bus
subclass = USB
ppt1@pci0:2:0:0: class=0x030000 rev=0xa1 hdr=0x00 vendor=0x10de device=0x1e04 subvendor=0x19da subdevice=0x2503
vendor = 'NVIDIA Corporation'
device = 'TU102 [GeForce RTX 2080 Ti]'
class = display
subclass = VGA
ppt2@pci0:2:0:1: class=0x040300 rev=0xa1 hdr=0x00 vendor=0x10de device=0x10f7 subvendor=0x19da subdevice=0x2503
device = 'TU102 High Definition Audio Controller'
class = multimedia
subclass = HDA
ppt3@pci0:2:0:2: class=0x0c0330 rev=0xa1 hdr=0x00 vendor=0x10de device=0x1ad6 subvendor=0x19da subdevice=0x2503
device = 'TU102 USB 3.1 Host Controller'
class = serial bus
subclass = USB
ppt4@pci0:2:0:3: class=0x0c8000 rev=0xa1 hdr=0x00 vendor=0x10de device=0x1ad7 subvendor=0x19da subdevice=0x2503
device = 'TU102 USB Type-C UCSI Controller'
class = serial bus
nvme0@pci0:3:0:0: class=0x010802 rev=0x03 hdr=0x00 vendor=0xc0a9 device=0x5403 subvendor=0xc0a9 subdevice=0x2100
vendor = 'Micron/Crucial Technology'
subclass = NVM
ppt5@pci0:5:0:0: class=0x0c0330 rev=0x10 hdr=0x00 vendor=0x1b73 device=0x1100 subvendor=0x1b73 subdevice=0x1100
vendor = 'Fresco Logic'
device = 'FL1100 USB 3.0 Host Controller'
class = serial bus
subclass = USB
then,I’ve launched the bhyve hypervisor using the following parameters :
bhyve -S -c sockets=1,cores=2,threads=2 -m 4G -w -H -A \
-s 0,hostbridge \
-s 1,passthru,1/0/0,bootindex=1 \
-s 8:,virtio-net,tap20 \
-s 29,fbuf,tcp=0.0.0.0:5920,w=1600,h=950 \
-s 30,xhci,tablet \
-s 31,lpc \
-l bootrom,/usr/local/share/uefi-firmware/BHYVE_UEFI.fd \
vm20 < /dev/null & sleep 2 && vncviewer 0:20
this is the error I get :
as u can see,the error seems to be "CPU does not support MWAIT. So,is there a way to disable this parameter between the kernel parameters used when CL boots for the first time ? thanks.
