Hi,
I am new to this distro, having used Fedora 32 before. In Fedora, I was able to easily disable Wayland and use X11. It was enough to set the flag:
[daemon]
# Uncomment the line below to force the login screen to use Xorg
WaylandEnable = false
in /etc/gdm/custom.conf.
How do I do something similar in ClearLinux? The Fedora method doesn’t work here
Yours sincerely
DKnoto.
