spoussa
September 12, 2019, 7:30pm
1
Hi
I want to create, clone and run clearlinux guests on clearlinux host using QEMU/KVM.
I can create and start the VMs via virsh and virt-clone. However, all the cloned VMs have the same host name. In other distros virt-sysprep or virt-builder can be used for the task (hostname set). However, none of those tools are available in clearlinux.
How can I do that?
Thanks, Sakari
Use hostnamectl
hostnamectl set-hostname <yourhostname here>
hostnamectl status
to check it worked.
You can also overwrite /etc/hostname
but I think that would require a reboot.
spoussa
September 12, 2019, 7:51pm
3
I know that but I don’t want log in to the vm. Let’s say I will create 100 VMs. I don’t want to do that manually.
delete /etc/machine-id
and /etc/hostname
before your clone it. Then a random name will be assigned.
spoussa
September 12, 2019, 8:30pm
5
I don’t want random name. I want to set it so I have names like vm-0,vm-1, etc.
If any tool is mising you can open an issue for Package Request
Sign in to GitHub · GitHub
You can also do this in the qemu-start command by adding hostname=name
in the -netdev
line. See: Documentation/Networking - QEMU
You could then modify your start_qemu,sh script the use a positional (${2}
) command-line parameter for setting a custom hostname on VM launch
EDIT: Oops, missed that you’re using virsh. Maybe virt-sysprep
but I don’t think it’s packaged in CL.
spoussa
September 13, 2019, 6:42am
8
Related to topic question
virt-sysprep - is not available on Clear Linux, right ?
But how to setup passwords for .qcow2 images if virt-sysprep not available ?
sudo virt-sysprep -a Centos-7-x86_64-GenericCloud.qcow2 --root-password password:super
I have to run this command.
is there any alternatives on Clear Linux ?
