I’m curios to know what you suggest as host environment for running VM ?
I’m using VMWare for 90% of my work and it work fine also in clear linux.
thanks
I would suggest ClearLinux.
And which virtualizer?
@paolol61 i use Virtualbox at home.
Witch one work best in Clear Linux ?
For now I have installed vmware and it works ok, but is Vitrual Box or Qemu better ?
