Hi Im trying to install clear linux on an xps but it always get stuck on boot loader can some one help me?
If you’re using a USB boot device did you follow this: https://docs.01.org/clearlinux/latest/get-started/bootable-usb.html
I have also used Rufus to create the USB boot device. It works as long as you don’t change the default volume label.
