Screen frozen, I can’t continue the installation at startup. Any advice? It only happens with Clear Linux Desktop. I really want to try. Same happens with DVD
What CPU are you using?
It’s not compatible with CL.
Oh Oh!! Ok Thank You…
keep trying. over an over until it works. it usually takes me 6 or seven trys to get clear linux going with 3960x, but once you get installed and going and updating it seems to work great with no freezes.
That’s not how Murphy’s law works. Are you the rebel in Murphy family?
It never works the first time. Usually I have to let it sit a week. Especially if NVIDIA driver install is needed for bringing up new hardware.
Did you try the clear-linux-check-config.sh, also verify it.
