(note: this installation uses a bash script called ‘create-fake-rpm’, who’s author issues the following warning:
!!! WARNING !!!
This is a big gun. You can easily shot yourself in a leg. Do not use this tool unless you know what you are doing. And if you know what you are doing - then think twice before you use it. You can easily destroy your machine with this tool.)
(unfortunately i wasnt able to install with rpm -i --nodeps or rpm2cpio because dnf download was coming up empty, the package url was a 404, and rpmbuild wasnt working with the rpmbuild folder in their github repo)
# bundle 'desktop' should be installed. if you dont -
# - have it installed, ensure you have the following:
# gtk3, webkit2gtk3, python 3.10, NetworkManager, NetworkManager-openvpn
sudo swupd bundle-add dnf c-basic devpkg-systemd devpkg-dbus network-basic devpkg-libsecret
export PATH="$PATH:~/.local/bin"
echo 'export PATH="$PATH:~/.local/bin"'>>~/.bashrc
pip install pythondialog pygobject psutil systemd jinja2 pyxdg keyring dbus-python bcrypt gnupg pyOpenSSL requests distro
git clone https://github.com/xsuchy/create-fake-rpm.git
cd create-fake-rpm/
sudo bash ./create-fake-rpm --build python3 /usr/bin/python3
sudo bash ./create-fake-rpm --build 3.10 'python(abi) = 3.10'
sudo bash ./create-fake-rpm --build pythondialog python3-dialog
sudo bash ./create-fake-rpm --build pygobject python3-gobject
sudo bash ./create-fake-rpm --build psutil python3-psutil
sudo bash ./create-fake-rpm --build gtk3 gtk3
sudo bash ./create-fake-rpm --build webkit2gtk4 webkit2gtk3
sudo bash ./create-fake-rpm --build NetworkManager NetworkManager
sudo bash ./create-fake-rpm --build devpkg-dbus dbus-x11
sudo bash ./create-fake-rpm --build xdg xdg-utils
sudo bash ./create-fake-rpm --build python3-systemd python3-systemd
sudo bash ./create-fake-rpm --build python3-keyring python3-keyring
sudo bash ./create-fake-rpm --build pyxdg python3-pyxdg
sudo bash ./create-fake-rpm --build jinja2 python3-jinja2
sudo bash ./create-fake-rpm --build python3-distro python3-distro
sudo bash ./create-fake-rpm --build dbus-python python3-dbus
sudo bash ./create-fake-rpm --build network-basic openvpn
sudo bash ./create-fake-rpm --build devpkg-libsecret libsecret
sudo bash ./create-fake-rpm --build NetworkManager-extras NetworkManager-openvpn
sudo bash ./create-fake-rpm --build python3-bcrypt python3-bcrypt
sudo bash ./create-fake-rpm --build python3-gnupg python3-gnupg
sudo bash ./create-fake-rpm --build pyOpenSSL python3-pyOpenSSL
sudo bash ./create-fake-rpm --build python3-requests python3-requests
for FAKE_DEPENDENCY in noarch/*; do sudo rpm -i $FAKE_DEPENDENCY; done
curl -O https://protonvpn.com/download/protonvpn-stable-release-1.0.1-1.noarch.rpm
sudo rpm -i protonvpn-stable-release-1.0.1-1.noarch.rpm
sudo dnf update --releasever 35
sudo dnf install protonvpn --releasever 35
if you try this, please let me know how it went
