After browsing around and trying to make my system finally work i decided to publish my personal software configuration guide created for myself to easier reproduce my configuration steps in future. Any advices or critics extremely welcomed!
Copy is here https://github.com/artempanin/clearlinux/blob/master/README.md
My Personal Clear Linux setup guide
Content
- General Settings
- Internet software
- Virtualization software
- Office / Notes software
- Software development tools
- System Administration
- Multimedia
General Settings
Cleanup (carefully check what you removing!)
sudo swupd bundle-remove evolution
sudo swupd bundle-remove geary
sudo swupd bundle-remove totem
sudo swupd bundle-remove gnome-music
sudo swupd bundle-remove gnome-screenshot
sudo swupd bundle-remove evince
Configure swupd
sudo swupd mirror --max-parallel-downloads=20
Additional network tools
sudo swupd bundle-add wget network-basic clr-network-troubleshooter
“Dash to panel” install
cd ~/Downloads && git clone https://github.com/home-sweet-gnome/dash-to-panel.git
cd dash-to-panel && make install
Installation finished, navigate to gnome tweaks and enable it at “extensions”
Freshpaper (BING wallpapers daily, love it!)
sudo pip install freshpaper
Just put a “freshpaper” in terminal , and wallpaper will be changed to most recent one
Wine (for winscp and other windows software)
sudo swupd bundle-add wine
Internet software
Install brave
sudo su -
swupd bundle-add package-utils
pip install python-dateutil
dnf config-manager --add-repo https://brave-browser-rpm-release.s3.brave.com/x86_64/
rpm --import https://brave-browser-rpm-release.s3.brave.com/brave-core.asc
dnf download brave-browser
rpm -U --nodeps brave-browser*.rpm
rm -f brave-*.rpm
sed -i 's\/usr/bin/brave-browser-stable\env FONTCONFIG_PATH=/usr/share/defaults/fonts /usr/bin/brave-browser-stable\g' /usr/share/applications/brave-browser.desktop
exit
Telegram
flatpak install flathub org.telegram.desktop
Protonmail Desktop Client installation with AppImage
mkdir ~/.apps
cd ~/.apps/ && wget https://github.com/unofficial-protonmail-desktop/application/releases/download/v1.2.1/Unofficial-desktop-client-for-ProtonMail-1.2.1.AppImage
chmod +x protonmail-desktop-unofficial*
sudo wget https://raw.githubusercontent.com/protonmail-desktop/application/master/src/main/images/Icon.png -O/usr/share/icons/hicolor/256x256/apps/protonmail.png
echo -e "[Desktop Entry]\nType=Application\nName=ProtonMail\nIcon=protonmail\nExec=.apps/Unofficial-desktop-client-for-ProtonMail-1.2.1.AppImage\nTerminal=false\nCategories=Network;" > ~/.local/share/applications/protonmail.desktop
update-desktop-database ~/.local/share/applications/
Nextcloud
flatpak install flathub org.nextcloud.Nextcloud
Virtualbox 6.1.14 Install
sudo swupd bundle-add kernel-native-dkms
cd ~/Downloads && wget https://download.virtualbox.org/virtualbox/6.1.16/VirtualBox-6.1.16-140961-Linux_amd64.run
chmod +x VirtualBox-*.run
sudo ./VirtualBox-6.1.16-140961-Linux_amd64.run
Optional! In my case without this steps my laptop is not booting anymore
Find your boot partition by running (it will be the smallest one and named “EFI System”)
sudo fdisk -l
Creating mount point for boot partition. In my case boot partition is /dev/nvme0n1p1
sudo mkdir /media/boot && sudo mount /dev/nvme0n1p1 /media/boot/
No idea why, but this worked for me
sudo cp /media/boot/EFI/BOOT/BOOTX64.EFI /media/boot/EFI/org.clearlinux/mmx64.efi
Now, add your user to vboxusers group , otherwise USB pass-through will not work
sudo usermod -a -G vboxusers $USER
Signing virtualbox modules
cd ~/Documents && openssl req -new -x509 -newkey rsa:2048 -keyout MOK.priv -outform DER -out MOK.der -nodes -days 36500 -subj "/CN=VirtualBox/"
sudo /usr/lib/modules/`uname -r`/build/scripts/sign-file sha256 ./MOK.priv ./MOK.der $(modinfo -n vboxdrv)
sudo mokutil --import MOK.der
Reboot!
sudo reboot
After reboot finish setup
sudo /sbin/vboxconfig
Now you can use Virtualbox as usual
Vmware Workstation 15.5.6
cd ~/Downloads/ && wget https://download3.vmware.com/software/wkst/file/VMware-Workstation-Full-15.5.6-16341506.x86_64.bundle
chmod +x VMware-Workstation-Full-15*
Now you need to run bundle. It will ask you about folder location , answer is /etc/init.d
sudo ./VMware-Workstation-Full-15.5.6-16341506.x86_64.bundle
Now we need to fix kernel modules , just follow the steps
cd ~/Downloads && wget https://github.com/mkubecek/vmware-host-modules/archive/workstation-15.5.6.tar.gz
tar -xzf workstation-15.5.6.tar.gz && cd vmware-host-modules-workstation-15.5.6/
tar -cf vmmon.tar vmmon-only && tar -cf vmnet.tar vmnet-only
sudo cp -v vmmon.tar vmnet.tar /usr/lib/vmware/modules/source/
sudo vmware-modconfig --console --install-all
Now juts run Vmware Workstation and finish installation.
Only one problem that i am not solved yet, that after restart you need to run Vmware modules manually.
sudo /etc/init.d/vmware start
Simplenote installation with AppImage
mkdir ~/.apps
cd ~/.apps/ && wget https://github.com/Automattic/simplenote-electron/releases/download/v2.0.0/Simplenote-linux-2.0.0-x86_64.AppImage
sudo wget https://raw.githubusercontent.com/Automattic/simplenote-electron/develop/resources/images/icon_256x256.png -O/usr/share/icons/hicolor/256x256/apps/simplenote.png
echo -e "[Desktop Entry]\nType=Application\nName=SimpleNote\nIcon=simplenote\nExec=.apps/Simplenote-linux-2.0.0-x86_64.AppImage\nTerminal=false\nCategories=Office;" > ~/.local/share/applications/simplenote.desktop
OnlyOffice Desktop Editiors
flatpak install flathub org.onlyoffice.desktopeditors
Flameshot screenshot utility
sudo swupd bundle-add qt-basic-dev
cd ~/Downloads/ && git clone https://github.com/lupoDharkael/flameshot && cd flameshot
cmake . && make -j4
sudo make install
cd ~/Downloads && rm -rf flameshot
Installation finished, navigate to Gnome Settings -> Keyboard Shortcuts (scroll to the bottom) -> +
Command: flameshot gui
Shortcut: bind something
Pycharm Professional Python IDE
flatpak install flathub com.jetbrains.PyCharm-Professional
Gitg
flatpak install flathub org.gnome.gitg
Atom
flatpak install flathub io.atom.Atom
Winscp (sorry, but love this one)
cd ~/Downloads/ && wget https://winscp.net/download/WinSCP-5.17.6-Setup.exe
This will install Winscp , if you running Wine first time accept & install all required libs
wine WinSCP-5.17.6-Setup.exe
EasySSH
flatpak install flathub com.github.muriloventuroso.easyssh
Sqlitebrowser
cd ~/Downloads && git clone https://github.com/sqlitebrowser/sqlitebrowser.git && cd sqlitebrowser
cmake . && make -j4
sudo make install
Multimedia
Audacious music player
sudo swupd bundle-add audacious
VLC
flatpak install flathub org.videolan.VLC
