I need to install Linux on a separate volume, but when specifying a destructive installation, the entire disk is specified, not there (you can’t select a volume), and if I choose an extended installation, the utility runs Gparted.
Tell me how to select the desired volume.
P. S. I probably chose the wrong topic of the question, I just do not understand English very well, but I hope for your understanding. Thank you in advance.
Did you read these three tutorials in the documentation ?
- Dual-boot Clear Linux* OS with Any GRUB-based Linux* Distro
- Dual-boot Clear Linux* OS and Windows* 10 OS
- Multi-boot Clear Linux* OS with other operating systems
Maybe, you have your response ?
Separate volume is a physical volume ? or logical ?
