Hello everyone,
Before I’m going to the main subject, I apologize in advance if my english is not perfect, since I’m from the baguette land I will happily give you a croissant.
I have seen a week ago that the vim bundle wasn’t compiled with +clipboard and since I’m currently a student (beginner to the marvelous linux world) which use vim almost everyday it was somewhat uncomfortable. So I wanted to build vim from source, which I did. After that I’ve installed YouCompleteMe a vim plugin which is a code completion plugin.
Error
The problem is when I launch vim in the terminal, I’ve got this error:
I’m not sure if this error is throw because python/dyn and python3/dyn.
What I’ve done
sudo swupd bundle-add deprecated-python2
sudo swupd bundle-add python3-basic
I’ve also did this ./configuration for vim:
sudo ./configure --with-features=huge \
--enable-pythoninterp=yes \
--with-python-config-dir=/usr/lib/python2.7/config \
--enable-python3interp=yes \
--with-python3-config-dir=/usr/lib/python3.8/config-3.8-x86_64-linux-gnu
and make && make install naturally.
I’ve also check vim with vim --version | grep python. This gave me the following result :
You can open an new issue on GitHub to request the clipboard support.
Also, it seems like you didn’t install ycm properly.
Actually I did some research. If you installed neovim, the clipboard feature is enabled (by default).
And I found this post helpful.
For example you can have set clipboard+=unnamedplus, then you can yank text into clipboard by pressing "+y.
Alternatively if you have
" Copy to clipboard
vnoremap <leader>y "+y
nnoremap <leader>Y "+yg_
nnoremap <leader>y "+y
" Paste from clipboard
nnoremap <leader>p "+p
nnoremap <leader>P "+P
vnoremap <leader>p "+p
vnoremap <leader>P "+P
You can for example, select text in visual mode, hit leader (defaults to \) , then y to copy to clipboard.
Thanks for you reply @doct0rHu. I’ve not installed neovim but does is it make vim support +clipboard ?
Also thank @btwarden for your reply, before I made this topic, I checked the topic Vim/nvim configuration file which you send me, but I was confused about the use of gvim (actuallly I’ve never used gvim) I was only using vim from terminal.
I’m going to reinstall YCM and save the copy/paste configuration for .vimrc.
neovim is a replacement for vim. It just supports clipboard by default.
Running gvim (vim with graphical support) with the -v flag makes it behave just like plain vim (which we compile without any graphical support, including +clipboard, to keep it from depending on large external libs like X11), except it has +clipboard compiled in.
I do not like to use neovim, since neovim does not support sending json to async jobs by default (I know this is arbitrary for most but I am a vim plugin developer).
If you compile vim from source you can get +clipboard and +python3 to work. see: [ How To ] Vim with Clipboard Support - #3 by Aleksei_Levykh
If you add --enable-python3interp=yes to the ./config command it will compile with python
checking Python is 3.0 or better... yep
checking Python's abiflags...
checking Python's install prefix... /usr
checking Python's execution prefix... /usr
checking Python's configuration directory... /usr/lib/python3.8/config-3.8-x86_64-linux-gnu
checking Python3's dll name... libpython3.8.a
Hi,
So, l’ve removed my source compiled vim and I’ve reinstalled the vim bundle.
I’ve did an alias for gvim vim = gvim -v.
And now when I launch vim I’ve got +clipboard, and I’ve reinstalled YCM, which work perfectly with the vim distribued bundle.
So I can say that my problem has been resolved, thank you again guys for your replies!
