when i execute /usr/bin/vi
it opens neovim.
my $EDITOR is /usr/bin/vi
my /usr/bin/vi
is not a link, and only 1 hard link to it exists
the bundle “vim-minimal” is not installled
i have both vim and neovim installed
/usr/bin/vi
is 14Ki while /usr/bin/nvim
is 3.8Mi
what is /usr/bin/vi
running /usr/bin/vi
on my system without vim-minimal installed opens VIM - Vi IMproved version 8.2.4611
The same happens after installing vim-minimal
Running $EDITOR opens the same program.
Neovim is not installed.
The /usr/bin/vi
binary is a special wrapper program written in C that follows this logic:
- If
/usr/bin/nvim
exists, run/usr/bin/nvim
. - Otherwise, if
/usr/bin/vim
exists, run/usr/bin/vim
. - Otherwise, if
/usr/bin/vim-minimal
exists, run/usr/bin/vim-minimal
. - Otherwise, run
/usr/bin/false
, effectively returning an error code immediately.
More background about “why it exists”:
In October 2017, we created a project named usrbinpython
that installed a binary named /usr/bin/python
that executed python2
if it was installed, and would otherwise execute python3
. We flipped the logic in February 2018: that is, /usr/bin/python
would prefer to run python3
if possible.
Later, we created two other projects, usrbinjava
(repo link) and usrbinvi
, that serve a similar purpose: to make a (fixed) decision about which versions (or variants) of a program to run if a generic program name is executed.
To be fair, one can argue that if /usr/bin/vi
exists, it should run the traditional VI editor when called. I think there’s a better argument for /usr/bin/vi
to not be a wrapper program compared to /usr/bin/java
or /usr/bin/python
. The latter two programs are selecting a preferred version of Java or Python to run, and the preference is defined by the OS contributors. For /usr/bin/vi
, it’s a variant preference, and there are fewer reasons from an “OS operations” perspective to inform what that preference should be…
I hope this clarifies the situation The outcome of running
/usr/bin/vi
(on Clear Linux OS) will vary depending on what bundles you have installed, and this behavior is by design.
