Hi there,
TL;DR
After upgrading to 5.18.2-1151
my system boots but gets stuck somewhere. I do not get a tty
to log in and no network either but I can Ctrl-Alt-Del to reboot cleanly.
Looking at the journalctl
logs, it seems that my configuration based on mdraid
(for /home
and swap
) may be hit by the same kernel issue that Arch has fixed here
I confirm that this flag is not set in the clr
native kernels:
# grep CONFIG_BLOCK /usr/lib/kernel/config*
/usr/lib/kernel/config-5.17.11-1148.native:CONFIG_BLOCK=y
/usr/lib/kernel/config-5.17.11-1148.native:CONFIG_BLOCK_COMPAT=y
/usr/lib/kernel/config-5.17.11-1148.native:CONFIG_BLOCK_HOLDER_DEPRECATED=y
/usr/lib/kernel/config-5.18.2-1151.native:CONFIG_BLOCK=y
/usr/lib/kernel/config-5.18.2-1151.native:# CONFIG_BLOCK_LEGACY_AUTOLOAD is not set
/usr/lib/kernel/config-5.18.2-1151.native:CONFIG_BLOCK_COMPAT=y
/usr/lib/kernel/config-5.18.2-1151.native:CONFIG_BLOCK_HOLDER_DEPRECATED=y
More details
I have two NVMe drives: one has boot
and root
, and then home
is mdraid
RAID1 and swap
is mdraid
RAID0 over the two drives:
# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10]
md126 : active raid1 nvme1n1p1[1] nvme0n1p3[0]
905819136 blocks super 1.2 [2/2] [UU]
bitmap: 0/7 pages [0KB], 65536KB chunk
md127 : active raid0 nvme0n1p4[0] nvme1n1p2[1]
10227712 blocks super 1.2 256k chunks
unused devices: <none>
and
# blkid
/dev/nvme0n1p3: UUID="0d54001e-585a-dc45-0888-77afcc788121" UUID_SUB="f23aed60-d216-9ac6-5e56-b7c6d12995cf" LABEL="hgcsynth1:home" TYPE="linux_raid_member" PARTUUID="b4c48e2c-5575-4826-85c7-f18a8e904e77"
/dev/nvme0n1p1: LABEL_FATBOOT="BOOT" LABEL="BOOT" UUID="5F40-EB7A" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="CLR_BOOT" PARTUUID="8e283b86-a608-45db-b263-99f30c6be2ca"
/dev/nvme0n1p4: UUID="11f14255-40aa-505c-925b-255c8c2b428e" UUID_SUB="34744ca4-113c-b4d8-1f19-6105f39dd31a" LABEL="hgcsynth1:home" TYPE="linux_raid_member" PARTUUID="7b36c967-8c4b-4d0e-863b-0554ababca7f"
/dev/nvme0n1p2: LABEL="root" UUID="979014be-15cd-46f9-a4da-40a7d5bcbdc7" BLOCK_SIZE="4096" TYPE="f2fs" PARTLABEL="CLR_ROOT" PARTUUID="e86f4d85-db2c-4219-a772-625e5b231115"
/dev/md127p1: LABEL="swap" UUID="1acbab90-a4cb-4efd-85a0-54133e92b7ec" TYPE="swap" PARTLABEL="CLR_SWAP" PARTUUID="25212bd4-1737-45fe-9726-97b556551e33"
/dev/md126p1: LABEL="home" UUID="c7596ae8-9370-405d-9ca0-f2ed7192e530" BLOCK_SIZE="4096" TYPE="f2fs" PARTLABEL="CLR_MNT_/home" PARTUUID="20722973-6e1d-41de-b0e0-3634991b2cf8"
/dev/nvme1n1p2: UUID="11f14255-40aa-505c-925b-255c8c2b428e" UUID_SUB="e35918e4-7888-28ca-536d-b08f938efdba" LABEL="hgcsynth1:home" TYPE="linux_raid_member" PARTUUID="81ff8cd1-1702-4602-a404-0e7320a2c104"
/dev/nvme1n1p1: UUID="0d54001e-585a-dc45-0888-77afcc788121" UUID_SUB="bf904adb-048b-5edd-2c56-b9c481fa4e94" LABEL="hgcsynth1:home" TYPE="linux_raid_member" PARTUUID="39abb04e-4f35-46fc-9f1c-01ae2c8bc688"
Even if I tried to use partition labels like CLR_MNT_/home
throughout, that never worked out of the box and I had to add since the beginning a fstab
for things to work for the mdraid
partitions:
# cat /etc/fstab
#[Device] [Mount Point] [File System Type] [Options] [Dump] [Pass]
/dev/md126p1 /home f2fs defaults 0 2
/dev/md127p1 swap swap defaults 0 0
When I comment all the entries out in the fstab
the 5.18.2-1151
system will boot and bring up the network.
Suspecting some md
numbering shenanigans I moved to using UUID
s and that works fine with 5.17.11-1148
# cat /etc/fstab
UUID=c7596ae8-9370-405d-9ca0-f2ed7192e530 /home f2fs defaults 0 2
UUID=1acbab90-a4cb-4efd-85a0-54133e92b7ec swap swap defaults 0 0
Unfortunately this still does not make 5.18.2-1151
happy.
What does it look like when 5.18.2
boots?
Under 5.18.2-1151
, dmesg
says that
[ 0.623752] md: Waiting for all devices to be available before autodetect
[ 0.623753] md: If you don't use raid, use raid=noautodetect
[ 0.623754] md: Autodetecting RAID arrays.
[ 0.623997] md: invalid raid superblock magic on nvme1n1p1
[ 0.623998] md: nvme1n1p1 does not have a valid v0.90 superblock, not importing!
[ 0.624015] md: invalid raid superblock magic on nvme1n1p2
[ 0.624016] md: nvme1n1p2 does not have a valid v0.90 superblock, not importing!
[ 0.624254] md: invalid raid superblock magic on nvme0n1p3
[ 0.624255] md: nvme0n1p3 does not have a valid v0.90 superblock, not importing!
[ 0.624271] md: invalid raid superblock magic on nvme0n1p4
[ 0.624271] md: nvme0n1p4 does not have a valid v0.90 superblock, not importing!
[ 0.624272] md: autorun ...
[ 0.624273] md: ... autorun DONE.
and that is correct, since the metadata version is 1.2 since quite some time:
# mdadm --examine --scan
ARRAY /dev/md/home metadata=1.2 UUID=0d54001e:585adc45:088877af:cc788121 name=hgcsynth1:home
ARRAY /dev/md/home metadata=1.2 UUID=11f14255:40aa505c:925b255c:8c2b428e name=hgcsynth1:home
At this point I should note that I do not have a mdadm.conf
and I am not keen on rebuilding the mdraid
arrays just for the kernel to tell me again that I do “not have a valid v0.90 superblock”.
Any ideas and suggestions welcome!
