I’m trying to test this feature on a particular LTE (EG25-G) device but I’m stuck.
Does anybody know if such a feature is already there or if I should build my own custom kernel to make it work (for example, open-wrt has been patched for it)?
Side note, I get the following if I type menuconfig:
/usr/bin/menuconfig: [Errno 2] No such file or directory: ‘Kconfig’ .
I’ve yet to search for more on this but Kconfig was in a bundle I installed.
Basically, I really need to answer that call.
Thanks for any information.
More info in this paper :
LTE Standard UAC Application Note V1.0 .
Section 4.2.2. UAC Use in Linux Devices
