I’m testing how well manuskript works under clear linux.
Manuskript is a perfect tool for those writer who like to organize and plan everything before writing.
Manuskript would be analogous to scrivener.
*) does clear linux have pyqt5?
*) can pandoc be separated from R-extras?
*) can pandoc be updated from 2.1.1 to newer? e.g. 2.7.x?
Thank you.
PyQt5:
sudo swupd install python3-basic
pip3 install PyQt5
Manuskript:
sudo rpm2cpio manuskript-0.9.0-1.noarch.rpm | (cd /; cpio -idv)
*) how to install in user’s directory instead of root file system?
*) maybe we need to create a “Clear Newbies” section for some of these questions. #clearnewbies
Add PyEnchant spell check tools:
sudo pip3 install pyenchant
swupd bundle-add aspell
Have you made a package request on GitHub?
Here’s hoping it (and its dependencies) will be ready for the 2019 National Novel Writing Month
opened 04:26AM - 06 Aug 19 UTC
package-request
Please consider adding a package for Manuskript, an open source authoring tool
Manuskript is written in Python3 and PyQt5.
Home Page:
https://www.theologeek.ch/manuskript/
Source code:
https://github.com/olivierkes/manuskript
License:
"...Manuskript is distributed under the GNU General Public License version 3 or (at your option) any later version..."
Thank you
opened 11:36PM - 02 Nov 19 UTC
closed 05:44PM - 04 Nov 19 UTC
new
package-update
bundles version = 2.1.1 (18 January 2018)
most recent stable release = 2.7.3 (1… 1 June 2019)
