Matlab installing
hi
Can MATLAB be installed on Clean Linux?
Thank you in advance
I believe the answer is yes. Ideally, matlab should provide all of its dependencies.
I’ve had no problems installing and running R2019b and R2021a, apart from having to disable the Chromium Embedded Framework (CEF).
Starting in R2021b, the editor uses CEF, so I haven’t got that editor to work at all; same for R2022a.
