So I just installed a bare metal install of Clear* Linux. Went to Mojang and downloaded the Minecraft Launcher.
Did the following
sudo mkdir -p /opt/minecraft
sudo tar xvf Minecraft.tar.gz --strip=1 -C /opt/minecraft
sudo swupd bundle-add java-runtime
/opt/minecraft/minecraftlauncher
It is not returning any errors and it just goes to the prompt for the next command.
daystars@daystars-pc/mnt/Saved/Minecraft sudo java -version
openjdk version "1.8.0-u222"
OpenJDK Runtime Environment (build 1.8.0-u222-ga-b00)
OpenJDK 64-Bit Server VM (build 25.71-b00, mixed mode)
That is the response from Java. From I understand this should be working. I have already fixed the mime-types in my Windows Manager so other things are working properly. Any thoughts?
if you ldd libcef.so this file is missing.
libgconf-2.so.4 => not found
Sure that it does but if you want to use resource packs, shaders or install any type of mods you need the Java Edition in my experience. In this case making it work natively just took some work. Figuring out why Steam doesn’t work properly now when installed with the games bundle.
For Minecraft Java Edition with the launcher it won’t launch after
Reason is gconf is not installed by default. After installing that it works fine. I will write up a walk through with pictures tonight and post it.
Steam not working when installed through the bundles is a completely different issue though. Something about an upstream memory error in /lib64/haswell/libc
This one seems to work and run the updates until it requires libdrm 32 bit, I haven’t found which bundle outside of games contains a 32 bit version of this library yet.
Yes the flatpak Steam works if you run default installation, since I store all of the proton / windows games in a different drive the flatpak doesn’t work for me. So trying to get the native install working.
Steam has to be installed manually. The /usr/bin/steam that comes from the games bundle is just a wrapper (linux-steam-integration) that is supposed to make Steam work better on Linux after it has been installed.
If you keep the games bundle installed and install Steam using the deb archive (like shown in this Phoronix article) it should work. Note: you might have to get a newer URL to the steam client download than in the article.
Minecraft requires a little bit more to actually properly run. The flatpak does the right thing and provides everything you need. You can totally do this manually but you’d have to keep it updated yourself, and flatpak makes that part trivial.
This is one of those cases where flatpak just does really well and we can’t really improve on in the OS.
I already have the minecraft-launcher working. I will try the flatpak tonight though, curious to see if it supports resource packs, shaders and what not to be honest. Installing GConf / Java runtime is all it took.
