It seems a lot of packages are using the autospec option floop-unroll (Sign in to GitHub · GitHub*), which adds “-mno-vzeroupper”, even when it is not clear that those packages benefit from avoiding emitting VZEROUPPER. It is compiling many packages under the x86-64-v3 target which correlates with Haswell and beyond with AVX2. It seems that Intel still recommends emitting VZEROUPPER, even on Skylake and its recent architecture revisions (Solved: What is the status of VZEROUPPER use? - Intel Communities), to avoid transition penalties between AVX and non VEX SSE. Some of those packages probably mix a lot of AVX and old SSE code and that could create negative results for the x86-64-v3 target. Is there any reason not to trust the compiler in some of those cases? Or maybe I’m misunderstanding something
So few specific things:
- Any binary compiled for v3 will not have any SSE encoded code in it (the assembler will upgrade them to vex encoding)
- Many many of our core libraries are shipped as v3 today (and growing)
- the compiler assumes a v1 or v2 universe with a bit of v3; but our universe is a v3 universe with a bit of legacy v2… so for performance sensitive packages we tell the compiler it’s in a v3 universe.
- quite a few still-v2 libraries aren’t actually using SSE vectorization so don’t matter
so by and large we’re on the path to be a v3 universe (and growing).
If we find a place where it matters, rather than putting vzeroupper back, we’re more likely switching the laggard to v3.
Have you lost your account or is this impersonating our Arjan?
Thanks for the reply @arjan. Indeed, what you’ve said here is true in the CL world.
I was curious, so I’ve used Intel’s SDE (Intel® Software Development Emulator) to check for non-VEXed SSE and AVX transitions in some of the few v2-v3 library interfaces… Unfortunately I accidently deleted my folder with all the scripts and testing results before checking if they were synced to github . It didn’t find any transition where VZEROUPPER was necessary.
TL,DR: These non-x86-64-v3 libraries aren’t using any SSE vectorization and the CL universe is increasingly fully v3.
This is indeed our Arjan
