I am having a problem in Konsole with the cursor. As I type, a black space appears between the cursor and my text, and it widens with each keystroke. If I move the cursor back, the black moves with, covering up text. I recorded it and posted it on Giphy since it’s a little hard to describe:
Not sure if this is related to the Clear Linux bundle specifically, but I’ve used KDE in other distros and never encountered this.
I tried several and the same thing happens. Interesting that you mention that, because I did change the color scheme before I noticed this. But setting it back to the original black on white did not help.
Do you remember what bundles you installed to build it? I seem to be missing several.
Searching for program xsltproc... /usr/bin/xsltproc
Searching for program convert... not found
WARNING: ImageMagick and/or rsvg binaries appear not to be installed.
This will cause errors later unless the generated pixmaps are already present,
eg supplied with a release tarball.
Searching for program xgettext... /usr/bin/xgettext
Searching for program msgcat... /usr/bin/msgcat
Searching for program msgmerge... /usr/bin/msgmerge
Searching for program msgfmt... /usr/bin/msgfmt
Searching for program po4a-gettextize... not found
File "./mscript.py", line 144, in <module>
ctx.find_prog_env("po4a-gettextize")
File "/home/james/Downloads/roxterm/maitch.py", line 903, in find_prog_env
self.env[var] = self.find_prog(prog, expand)
File "/home/james/Downloads/roxterm/maitch.py", line 889, in find_prog
p = self.__find_prog(prog, self.env)
File "/home/james/Downloads/roxterm/maitch.py", line 1386, in __find_prog
raise MaitchNotFoundError("%s program not found in PATH" % name)
maitch.MaitchNotFoundError: po4a-gettextize program not found in PATH
