Hello, Anki stopped working, console/terminal messages are as follows:
Anki starting...
Initial setup...
File "<string>", line 1, in <module>
File "aqt", line 52, in <module>
File "aqt.gui_hooks", line 11, in <module>
File "_aqt.hooks", line 18, in <module>
File "aqt.qt", line 20, in <module>
File "aqt.qt.qt6", line 17, in <module>
ImportError: /usr/local/share/anki/lib/PyQt6/Qt6/lib/libQt6Quick.so.6: undefined symbol: _ZTVNSt3pmr25monotonic_buffer_resourceE, version Qt_6
The application did work fine in the past, what could be happening? Maybe a missing bundle?
I’m afraid to say that the problem is back… this is what terminal says:
Anki starting...
Initial setup...
File "aqt.qt.qt6", line 12, in <module>
ImportError: /usr/local/share/anki/lib/PyQt6/QtCore.abi3.so: undefined symbol: _ZN14QReadWriteLock16destroyRecursiveEP21QReadWriteLockPrivate, version Qt_6_PRIVATE_API
Anki starting...
Initial setup...
Preparing to run...
Wayland support is disabled by default due to bugs:
https://github.com/ankitects/anki/issues/1767
You can force it on with an env var: ANKI_WAYLAND=1
Qt warning: QGuiApplication::setDesktopFileName: the specified desktop file name ends with .desktop. For compatibility reasons, the .desktop suffix will be removed. Please specify a desktop file name without .desktop suffix
Qt warning: QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Qt info: Sandboxing disabled by user.
Qt fatal: Cannot mix incompatible Qt library (6.6.1) with this library (6.6.2)
Aborted (core dumped)
I love Clear Linux, but the updating to cutting edge packages (in this case, Qt6) tends to break applications… Anki was working fine again for a few weeks and boom, it’s broken again.
Wish there was a more stable branch or something…
OK! I managed to fix it after a while. The problem was that Clear Fraction was interfering with it’s libraries, after removing the 3rd-party repo and all it’s traces, Anki is working fine again
