I am currently going through a process where you create a Clear Linux VM in Virtual Box and then use the supplied lxd-convert tool which converts the disk to a lxd image.
At the moment I am trying to find a Clear Linux release that will stay stable. My last known good stable at the moment is 36600, but since the update runs in the background at boot, it rolls the release forward and hangs the VM.
So I am working my way backwards through the release server looking for a build that will stay stable until I can get the image converted.
After several attempts, I was able to get the lxd migrate utility to work the disk image. It won’t create a lxd VM at all, punts completely, but the container conversion kept getting rsync errors near the end. Says that the disk is full, which is clearly not the case as there was plenty of disk available. It was educational, not so much on the Clear side, but just how clunky LXC/LXD is. Which was the point.
