Hi there, I’m having trouble completing a long-running Rails / Postgres process in Docker on a VPS that is running Clear Linux. After somewhere around 5 hours the entire system becomes unresponsive and I can’t login via SSH, requiring a forced reboot. The VNC output shows the following errors:
On the same VPS (same node) rebuilt with Debian 11 the same process does not have this issue. I don’t understand the nature of these Clear Linux error messages or if anything can be done. Thanks in advance for the help.
