After upgrades, Skype doesn’t starting. Tried both from Gnome menu, and command line “flatpak run com.skype.Client” - no start.
Same issue here! Cannot start Skype anymore…
I’m not able to reproduce this. Maybe try to execute flatpak update
before launching Skaype?
Yes - it works after “flatpak” update. Thanks.
A bit confusing - work with both bundles and flatpak, though.
Prior to this, have you recently installed/update your GPU driver? Because that’s one situation you have to run flatpak update manually.
No, nothing with GPU driver. Still “flatpak update” solved a problem
