Hi,
I just finish to install the OS on a matebook 13 (AMD) , then I installed the VMwareplayer for linux , but when I try to run it is asking to install the module on the kernel and it fail with eror
GLib does not have GSettings support.
If you need to do virtualization on a linux machine, use kvm instead of vmware. I struggled quite a bit with vmware workstation on ubuntu 21. So I removed vmware packages and configured kvm, went thru smoothly. vmware is a lousy product
