good morning to all.
I’m trying to install vmware workstation pro 17 but I always have errors compiling vmmon and vmnet.
I followed several posts but without finding a working solution.
Can someone help me?
thanks
martin
thanks
martin
The docs are not clear on this, and there are quite a few reports on VMware workstation in the forum. These are the steps that work for me.
sudo swupd bundle-add kernel-native-dkms
sudo mkdir /etc/init.d/
# install vmware-player-17.0.2 as usual
# start the player GUI and go over the wizard, then exit it.
sudo vmware-modconfig --console --install-all
sudo systemctl start vmware
# if the service started in the last step,
# start the Player and install VM from iso.
I expect that the step sudo vmware-modconfig --console --install-all will need to run after every major kernel update.
Today, I have the same issue. I’ve opened an issue in GitHub and got feedback, but It seems incompatible with the latest 6 kernels branch.
