That’s it! That worked. Never thought to add a config file, thanks!
As far as the sound devices not being detected, I ended up performing a fresh copy. I think I need to change the topic to something more suitable, LOL!!!
Hi - I had the same problem, I created the config file above and it fixed it. Except my network won’t connect to any of my VMs. I have to enter this in the terminal sudo /etc/init.d/vmware start then it starts the services and my network will connect. Is there one of the services that could be added to the config file that was created that is missing?
Hi thanks for the quick reply it’s most appreciated. I entered the command you mentioned and added the vmnet at the end. I rebooted but it still didn’t work, When you said check for /dev/vmnet0 _ /dev/vmnet1 _ /dev/vmnet8 what exactly do you mean? I know these are the vmware network adapters that are created by vmware. Should I see them in the terminal? Please forgive me as I’m a newbie with Linux.
Thanks - No it’s wasn’t in the terminal widow. The command you supplied worked up until I rebooted. Then I have to enter one of the three to get the network to start:-
or vmware-networks --start
or sudo vmware-modconfig --console --install-all
Or if I open the virtual network editor then it will start also.
