sudo swupd bundle-add kernel-native-dkms
Then installed Vmware Workstation
Vmware Kernel Module did not install, machines wont start
Tried uninstalling Vmware
vmware-installer -u vmware-workstation
Vmware workstation Icon is gone but Player icon still on, cant reinstall vmware workstation, cant uninstall it. No Player available for uninstall, says workstation still installed
Appreciate help for uninstalling, have seen multiple github plages, discussions, still got stuck here. Cheers, thanks in advance i will keep looking into it.
Got it running by
sudo rm -rf /etc/vmware*
download latest vmware player 17.01 instead of workstation
installed fine, vm started ok
Also added dev-utils bundle but i dont think it did anything
